Tayda & Axial caps
Started by selfdestroyer, July 11, 2016, 07:59:05 PM
Anyone else notice Tayda is selling axial caps?
http://www.taydaelectronics.com/catalogsearch/result/?q=AXIAL+CYCLOIDAL
Manufacturer: JB Capacitors
Manufacturer Part No: JFGA 0.1uF 100V +/-5% Bulk RoHS
Datasheet: http://www.taydaelectronics.com/datasheets/JFGA-Capacitor.pdf
call me interested..
Muadzin
Why are people so obsessed with these damn things? Rule of cool?
Adam_DIY
I want to build a pedal with some because I've never used them before also Ivlark has some layouts which these should fit perfectly.
EBRAddict
For poly axial caps that's pretty cheap, but I don't know anything about that brand.
jball85
They're good for tagboards/turrets or point to point stuff.
I believe the company in question also manufactures higher end poly axial caps.
http://www.jbcapacitors.com/Plastic-Film-Capacitors/JFX-Premium-Metallized-Polypropylene-Film-Capacitors-Axial.html
47u 100v for $2.60 is pretty good. Not sure what the hell I would do with that, but it's cheap.  ;D
Quote from: culturejam on July 13, 2016, 03:53:26 PM
Cathode bypass cap in tube amp.
Quote from: davent on July 13, 2016, 05:38:02 PM
Sure, but that's not something *I* am likely to be building, thus my comment. What in a pedal would I do with it? Probably nothing useful.
Quote from: culturejam on July 13, 2016, 06:42:34 PM
Ah, i'm with you there, just a big space hog in a pedal.
But they look so cool! lol
I am that shallow..
They definitely look cool. I put them in my guitars if/when I need to do electronics mods.
That would certainly work, but considering the costs involved in a Tube Amp build, I am not sure this is where I would personally save money.
I have some Nichicon caps like these.  I got them 20 years ago as samples, but I don't remembering them being all that expensive in the first place.
I just haven't come across many high value/low voltage plastic caps. The one i'm familiar with is a Bennic available through Solen 47uF/160v ~$12 cdn and huge. I've used plastic caps up to 5uF as cathode bypass, still quite small and reasonably priced.
