Serendipity-no drive
Started by slimtriggers, July 26, 2011, 11:44:13 PM
slimtriggers
Just built up a Serendipity and it's not giving me any love.  I get signal in bypass, signal when it's switched on, LED works, but no drive.  The drive control acts like a volume control.  The volume control also acts like a volume control. The voice pot seems to be working properly, and it's hard to tell if the tone knob is doing anything.
I did sub a TL072 instead of the AD712.  So far the only thing I've tried is switching the transistors around in case I had the pinout backwards.  No change when I switched them, though.
I'll go through and double check my resistor values tonight.  I probably should check to make sure I don't have the pots mixed up, too.
Any other suggestions?
cjkbug
#1
did you use 2n700's or some other fet? I had a stubborn vero build of this circuit with similar behavior. it was a problem with the fets. I replaced them and it was fine. bs 170's work great in that circuit too.
What brand of 2n7000 are they?
cjkbug
mine where cheap ones from tayda. I bought a bag of 100 and I've had a few duds
It's a bit of a pain slimtriggers, but socket the two transistors and try putting in some diodes there like 1n914. If you get distortion then it's a matter of either different pinouts or perhaps bum transistors.
slimtriggers
Yeah mine are from Tayda as well.  I socketed the transistors, so swapping them with diodes will only be a minor inconvenience.  I'll give that a shot.
I'll let you know how it goes 8)
slimtriggers
I tried 1n4148's in place of the transistors, but no change.  I tried 2 more transistors (off the same strip, though) but no change there either.
All the resistors check out, and my pots are correct.  Maybe I'll try a 4558 just in case...
hmm... it's almost like there is a short somewhere in the neg feedback loop of IC1A.  A solder bridge perhaps?
This is a weird one.
slimtriggers
Tried a 4558, but no change.  Would an IRF510 work if I could finagle the leads appropriately?  That might be a tough one to try out, though.  I only have 1 BS170, but I may switch it into both spots to see if there's any change.  BS170 has pinout opposite of a 2n7000 if I understand correctly.
I would take some pics, but I haven't seen my camera since we went to Gettysburg a few weeks ago :(
jimmybjj
Can you post hi res pics of both the component and solder sides inclusive of the wiring?
Pcbs no longer available
Voltages on the IC are in order, as well.
slimtriggers
No way to take a pic right now, but here are the voltages.
[attachment deleted by admin]
slimtriggers
Volts at the transistors:
slimtriggers
OK.  Found the camera :)
slimtriggers
Good Lord the soldering looks ugly all blown up :P  I already see a couple of spots that may be suspicious.
