Total recall 2.2uf
Started by darrenw6000, June 24, 2016, 08:22:16 PM
darrenw6000
The 2.2uf bipolar cap in this build, is that just a 2.2uf film or a special cap?
If it's specced specifically as bipolar, then it's probably a bipolar electrolytic (most electro's are polarised.)
This would have been used in place of a film cap for physical size reasons.
darrenw6000
I have got a small 2u2 film cap by wima. Couldn't I use this for this project or does it need to be electrolytic.
Should be fine as long as you can fit it to the PCB.
It just has to not have a polarity so not a straight up electroyltic or tantalum.
There's also the option of tying the negative lead of 2 x 4.7uF Electro caps together and putting the positive lead of each in to the pads as it was on the original DMM.
darrenw6000
Orbis_Ignis
I just used two 1uF film caps in parallel to get as close to 2.2uF as I could get. I picked the ones I found that were the largest values. I think I ended up with 2.1+uF
darrenw6000
ok. what about the trimmer positions, i am useless at getting them right, where are yours set?
