Parts Disparity
Started by K3yPr0gg3r, May 19, 2016, 08:44:09 PM
K3yPr0gg3r
Hi,
I have read much about counterfeit DIY pedal components. Saw some alarming price discrepancies in a search I did last night for diodes. Company A price for 1n34a's $0.81 per, (Tayda $0.24). Price for 1n60's $0.85 per, (Tayda $0.05!). Price for 1n270's $2.59!! Tayda $0.26. 1n5817's were going for $0.71, while Mouser had them for $0.43. Are higher priced components REALLY better, or is a 1n270 a 1n270 anywhere?
Thanks
I've never had problems with parts from Tayda. I'm certainly not the most experienced guy on here though. They certainly don't have everything though, and some things that can vary in quality quiet a bit, like a PT2399, I would pay a little more for.
Tayda's resistors have very thin leads on them, and certainly don't feel as nice as xicon resistors, but they get the job done.
Just remember, it's worth checking everything with your multimeter before you put it in a solder it.
GermanCdn
As a general note, Tayda germ's are way off spec with Fv all over the place.   Does it matter?  In some cases, sure it will.  If it's in a comp like a Bearhug you want good quality components.  If it's in a wild fuzz that goes from insane to OMG please make it stop, not so much.
1N5817s in a polarity protection circuit - not so much as it is not in the audio circuit.  And you should be able to find those for super cheap.
Long story short - the quality of component required is highly dependant on the function of that component.  I've got expensive 1N34's and cheap 1N34's; the expensive ones I use when they are the sole function diode in the audio path of a circuit.  The cheap ones I use if I'm building a circuit with a pile of clipping options.
The only problems with expensive germs is that they break as easily as cheap germs, so be careful.  It's a lot more painful when you crack the glass on a $3 diode.
K3yPr0gg3r
Thank you for  the incite.
BrianS
Like I told you on one of your other posts the only thing I've gotten bad from Tayda was some ICs and one cap. I think what the other guys have said is spot on.
From what I have read on 1n34a's is that the majority of them come from Asia. This guy sells them for .49 a piece and he says he's tests some of them to make sure they are for real. I haven't bought any but he's been around a long time.
https://www.mikeselectronicparts.com/product/1n34a/
Paul DIYGP (link above in header) sells a lot of items and always has good prices. The only downside is it can take awhile to get things from Aussie land.  He's a really good guy and will go out of his way to help you out.  I trust everything he sells.
The only other thing I can say is buy in bulk. Diodes 5817's, 914's, 4001s and others in the 4000 series are in almost any pedal you build. 100 5817s from Mouser brings them down to .12 a piece.  I would also check Allied Electronics also. They sometimes have better prices.  100 5817s are .074 a piece. Just make sure you calculate postage when buying from multiple places. Buying the 5817s from Allied plus shipping (USPS cheapest) will almost be the same price as buying them from Mouser.
Went through a ten pack of Tayda 220n ceramic disc capacitors a couple of days ago, because i needed a 220n disc cap, two were in the high 200 teens, two were in the 150n's, there rest were in the 170n's, to me not acceptable, i really have no reason to use Tayda and haven't in a very long time.
Quote from: davent on May 20, 2016, 12:46:45 AM
Wow, Sounds like if my dmm could test caps I'd have a lower opinion of Tayda.
These were ceramic disc caps, not film box?
Quote from: alanp on May 20, 2016, 01:00:40 AM
Yes Alan, just for a Lumen switch.
Jules
1n60 is also the part no. for a silicon diose, a schottky I thinks.
The 1n60 diode from Tayda is not a germanium diode.
EBRAddict
Were these +/- 20% (or worse) parts?  176n is "in spec" although it appears yours were hand picked to be on the crap end of the distribution.
Tayda generally gets sort of divided opinions.  Some are OK with the quality of parts and some aren't.  I generally fall on the side of not.
I've had more Ge diodes from them that were out of spec than in spec.  And some of them were wildly out of spec.  If you get them from there, they should be screened at the very least.
Pots & sockets is all I get from Tayda anymore. My build quality has improved greatly once I moved over to Mouser,MKLec, BLMS and Small bear only.
K3yPr0gg3r
I've got 20+ Tayda links saved for transistors, ICs, and diodes. Included them in my list of supplier due to a post I read a few months ago about where to get components. Tayda was mentioned favorably for certain items. Never heard of MKLec, but found the site and looks promising! The thing I like about DIY Guitar Pedals (Paul) is that ALL Caps are in Nanofarads!! Can't tell you how frustrating it is as a "new builder" to have to convert to buy at Mouser or SB. Anyway, I guess I'll hunt for the Tayda parts elsewhere... Thank you.
Quote from: selfdestroyer on May 20, 2016, 04:22:20 PM
The funny thing is that passives really aren't all that much more expensive at Mouser, Digikey, Newark or Allied.  There are certain things that Tayda is definitely much cheaper for, but often the savings is marginal, especially if you are willing to buy 50-100 of each part at a time.  Not necessarily practical for somebody that wants to build one or two projects, but if you are in the hobby for the long haul, you can get much better quality parts.
