Deadringer boost switch
Started by GuitarManiac32, July 12, 2011, 04:51:12 PM
GuitarManiac32
Hi everyone!
I finished building the Deadringer, but I have a question about the boost switch. Can I use a DPDT switch or does it have to be 3PDT? I just wired a DPDT switch for the boost but it doesn´t work right. The pedal does sound really great but the boost isn´t working. I guess the easiest solution would be changing the switch but if a DPDT would work...
Thanks for the help in advance!
JakeFuzz
The boost switch can be DPDT, in fact if you didnt want to use a boost indicator LED you could even use a SPDT footswitch. That's strange that it doesn't work. Double check your switch wiring and that the boost pot is in there okay.
Could you take a picture of your current wiring.
GuitarManiac32
Thanks for the reply! I´ll go through the connections and try to see what´s wrong. I´ll try to post pictures of my bowl of spaghetti later  ;D
