Clean octavio
Started by adam_bz, March 05, 2016, 05:19:49 PM
adam_bz
Where's the octave input section for the retro grade on the schematic? Looking at removing the fuzz totally. Cheers
beneharris
Look at the right portion of the schematic. I don't have it up, but I think its a .33mf electro, going into the transformer. The diodes and the transformer create the octave.
You can't remove the fuzz entirely. You CAN remove the octaving.
The fuzziness is created in two ways. First, you've got a couple very high gain stages in a row, and the signal is clipped by the rectifying diodes that create the octave. You can remove the clipping by shorting the diodes, but you'll still have the huge amount of gain to deal with.
If you're looking for a clean upper octave, there's no such thing in analog. The octave is dirty because the only way to create an octave in an analog device necessarily produces a huge amount of distortion.
jball85
You could just go with a Green Ringer.
