Timelapse details
Started by joesatch, March 04, 2016, 01:51:29 PM
joesatch
will the Timelapse support (4) MN3005's? Hopefully so to get close to a ehx tt1100. My BBD's await. Any eta on the project?
Sorry, no. There's only room for two BBDs on it. No definite ETA but I will be working on it this month after these 1590G boards get out.
joesatch
sounds good.  i'm gonna build one as soon as they're available.
RyanB
Hey! So it sounds like the timelapse will use the MN3005s? Is it designed specifically for those chips or will it take others? A friend and I are hoping to build the DMM clone soon but having a DMM or similar with tap tempo would be awesome. :)
archaos
OMG !
Please Brian, let us know further details about that new circuit. I assume this one will replace the ABDX ? What will be the maximum delay time ?
Thanks.
Mehr Licht !
joesatch
1100ms would be a game changer
Max 2 x BBDs = 600mS of clean delay (DM-2 style) tops, if you want 1 second you'll be looking at some very dark, dirty and murky delay.
neandrewthal
What about using a Total Recall Expansion Board with Four MN3005 instead of 3008? Or will be just completely incompatible with this project?
Any heads up on what controls it will have and what box it will fit into?
AwesomeTyler
^^also extremely interested in the above question^^
Are the only dissuasions due to board real estate?
Ralfg
What's the voltage going to be on the Timelapse?  I'm curious because my effects loop of the amp I currently play blows every delay pedal I've tried away and something tap-able with high headroom would be awesome.
stecykmi
Quote from: Scruffie on April 02, 2016, 11:09:11 PM
very true, not a delay expert but long delays on BBDs are not usualy worth it imo.
Quote from: Ralfg on July 23, 2016, 02:08:29 AM
It will be 9v-powered but I will be experimenting with up to 15v to see how it does.
daleykd
Any chance of the Timelapse having tap tempo?  (I just realized today that the TT-1100 was back in production b/c of XVive.  Sorry; I live under a rock.)
Quote from: daleykd on August 15, 2016, 03:58:43 PM
ähhmmm, the description literally says "Tap-Tempo Analog Delay"  ;D
daleykd
Quote from: m-Kresol on August 15, 2016, 04:10:13 PM
CURSES!  I'm getting all my delays confused.  This is the PCB I've been waiting on all year!!!
