LED Polarity as Diodes?
Started by Cornholio, February 25, 2016, 09:54:26 PM
Cornholio
In the Moodring and Deathklaw schematics are the leds positioned with the positive on the square pad and negative on the round pad? I ask because I just finished a Krypton Phasor and had to reverse the led since I originally thought the square pad meant positive? Any help is appreciated, I'd rather not have to re-solder these two, thanks!
Cornholio
I dug deeper and seems I got the answer, never thought about the silk screened image: http://www.madbeanpedals.com/forum/index.php?topic=19432.0
Betty Wont
Thank you for that. This is another inconsistent standard. I've found that new world designs have indicator LEDs that tend to be square positive while european boards are square negative. I usually only see LED clipper and LED/LDR marked with the useful round/flat screened image.
