Nom Nom pedal transistors?
Started by cdevor88, February 20, 2016, 03:44:04 PM
cdevor88
Thank you!  That leads me to my next question,  I have everything else assembled and now my pedal doesn't work.  It will bypassbut when I press the switch to turn on the pedal no sound.  Do I HAVE TO remove that resistor for it to function?
Jebus
Quote from: cdevor88 on March 13, 2016, 04:57:09 PM
Nope, you don't have to remove it. Double check the wiring and component values. If that doesn't work, start a tech help thread with the needed info: http://www.madbeanpedals.com/forum/index.php?topic=902.0
cdevor88
Last question on the Nom Nom .  just realized I bought and soldered 3296w trimpots instead of the Bourns 3362......will they work or do I need to buy the right obese and swap em out?
Are they the right value? They'll work fine if  fhey are.
