Etcher's Paradise - Release Announcements
Started by madbean, February 14, 2016, 04:34:19 PM
Quote from: chuckd666 on July 28, 2016, 06:32:59 AM
Isn't the extra stage at the front of the circuit?
Huh, so it is. I had just been reading r.g. Keen's easy mods page about putting a big muff tone control right befor the volume control on a circuit so I figured that's where it was on a muff. I haven't look a a Muff schematic for ages.
It's the buffer that is always present in the G2 design. There is a separate bypass buffer which is the one not included on this project.
EBRAddict
The two buffer sections combined with the first BMP stage form a bandpass filter. I forget the exact 3dB down points but it was around 80Hz and 1kHz. I replaced the first three stages with an equivalent opamp-based MFB filter with gain 10 and couldn't tell the difference.
peterc
Affiliation: bizzaraudio.com
FlimFlam
- Based on the EHX Double Tracker
This is a slapback echo which I've set up for 9-12v DC supply instead of 18v like the original.
artstomp
#22
..will the FlimFlam still be useable as intended if i use MN3008...what modifications should be done to at least extend the delay time....i'll be using my 2 MN3005s for a total recall build and still have an MN3008 collecting dust on my drawer...tnx
Total Recall
- Based on the EHX DMM
This is the same project as the manufactured board except for 1) it goes in a 1790NS and 2) does not include the BBD expansion board (so 2x MN3005 only)
1790NS: https://www.pedalpartsplus.com/product-p/1700.htm
Quote from: madbean on May 18, 2017, 02:11:47 PM
Total Recall
Holy Smokes! this is gonna be awesome!
stringsthings
Nice!  Gotta save up for some MN3005's.
All You Need Is Love
Quote from: stringsthings on May 18, 2017, 07:58:10 PM
Paul has the Xivive ones and I think they end up being cheaper than $20 USD.
storyboardist
Total Recall
Holy crap, I think that's the biggest etchable board for an effect I've ever seen.
Guy behind Effects Layouts
Quote from: storyboardist on May 19, 2017, 01:08:19 PM
Then you should check out the layout (not mine) for the Ring Stinger :)
Quote from: madbean on May 19, 2017, 01:16:12 PM
Yeah that thing is MASSIVE! plus there are 2 add on boards also...
