Strat dummy coils???
Started by Leevibe, February 04, 2016, 04:40:45 PM
I recently got a strat as a late Christmas present from my amazing wife. I had posted a NGD pre-crash. (MIM, LPB, SSS, maple fretboard) Anyway, I'm contemplating which mods I'm going to do, and one thing that's intriguing me is the idea of putting in a hum cancelling dummy coil, mainly for the bridge pup.
From what I understand, these can be pretty effective in reducing or eliminating hum, and have much less impact on tone than stacked humbuckers. In fact, a little treble suckage on the bridge wouldn't hurt.
Looking for opinions from anyone who has tried this approach. I know I could just put a humbucker in there. Don't want to.
brucer
I can recommend the L-290SL (L="lead"=bridge) pickup from http://wildepickups.com/Wilde_Bill_s_NF_Singles.html (no affiliation).  I think it's essentially what you're talking about design-wise ... and I wouldn't know how to DIY that  :-[
john_p_wi
I haven't been to Rob DiStefano's site for a loooong time, kinda out of the guitar building bug.  I know that he recommended cheap import pick ups for this purpose.  Read more here:
http://www.frettech.com/frettech/dummy/index.html
mjcyates
Not necessarily what you are asking about, but I added a Mooer Noise Killer to my board to deal with my Strat Lead pickup noise. It is very small, only cost 75-80 bucks and works pretty darn good. I am fairly certain it is based on the ISP Decimator circuit.
I actually just tried doing a dummy coil a few days ago. Did not get results as of yet. I used a cheap pup that measured around 5.6k. Did not seem to make a difference...in fact it seemed to make it a little more noisy if anything. Gonna try working on it some more.
Quote from: madbean on February 04, 2016, 08:54:55 PM
Did you try flipping the leads? I know one way should cut noise, the other way will increase it. Keep me posted as to what you find out.
Quote from: john_p_wi on February 04, 2016, 06:04:17 PM
That's an interesting read.  I neglect playing my strat for noise issues, and it's so bright I normally play with the tone wound off a little.  The dummy coil might be worth trying, thanks for the link :)
drolo
Ideal would be something like the Suhr Plate which is a larger coil, wound with thicker gauge so the impact on tone is minimal and still cancels as much hum.
I had done a little experiment on my jazzmaster here:
http://www.davidrolo.com/2013/10/24/dummy-coils-for-dummies/
I am really happy with how it turned out.
I did the same on a tele, the coil had to be a little smaller but it still worked great
john_p_wi
Sorry that I have not refreshed my memory on this, another issue if I recall is that you can not use the now normal reverse wound middle  pup.
There's a lot of info on this subject here.
Note that I haven't tried this yet, I bookmarked the site a while back thinking I will get to it some day.
Quote from: john_p_wi on February 04, 2016, 10:11:10 PM
I'm not sure that would matter once the magnets are removed. All your left with is a coil. As far as direction of the coil making a difference, my memory is also kinda sketchy but maybe because magnetic fields run orthogonal to the coil? (yes it's been 20 years since I sat in college Electricity and Magnetism)
Quote from: drolo on February 04, 2016, 09:44:08 PM
Looks like you found the same article I read:  huge coil with fewer turns. Is there room to fit one in the trem cavity if I use fine enough wire?
I'll probably start with a crappy strat pickup and just pull the magnet and slugs for starters, but I kind of want to try the big coil idea.
drolo
the trem cavity seems to be a good idea. or even in the control pots cavity
john_p_wi
Quote from: madbean on February 05, 2016, 12:29:33 AM
Lol, it's been 30 years for me...
The electrical guys (I'm mechanical) at work build the equivalent of the Qi charger into hand held medical devices.  I'll have to see if I can grab a coil that is wound flat and stuck to a poly sheet and investigate.  It would be super easy to stick to the inside of the trem cover, although I don't use them.
I'd vote for just copper shielding tape, if you do a good job with some star grounding it's really effective, my strat is silent with it.
