Rullywow/King Tut problem
Started by thesameage, January 22, 2016, 02:36:33 PM
thesameage
Any thoughts on this issue, guys?
I have a King Tut/Pharoah clone that Rully actually pop'd that I put together recently. I'm having an odd issue. IT works fine when I'm at home jamming along. However, at band practice when I have it in a chain, it will be great, then, I'll take a break and come back and the King Tut isn't passing sound. The led will be fine but it suddenly passes no sound after being fine.
Any idea what the issue might be?
WAsn't able to try it again when I got home last night, but I'm guessing that it will be fine.  Could something be building up that peaks after 15 minutes of playing?
The circuit sounds amazing on bass... a great dirty boost through a real fuzz... not sure what's going on here.
pryde
I suspect a loose connection in the audio path. Run a signal through it and start chop-sticking around all components, switch, and jack solder joints and see if you can get it to act up.
thesameage
Good call... gonna chop stick tonight.
thesameage
Ended up that a spec of solder somehow got lodged between the pads on the output jack!
