Rissole help
Started by jimilee, May 11, 2015, 10:13:05 PM
My rissole isn't enveloping. At first the lights were pulsing and now they're not doing that either. I reflowed everything and got al the modes seemingly working. With the blend pot all the way up, I got no audio.
Pics and voltages to follow:
IC1
1 4.5
2 4.5
3 4.5
4 9.14
5 3.4
6 4.5
7 4,5
8 4.5
9 4.5
10 4.5
11 0
12 1.73
13 4.5
14 4.5
IC 2
1 1.9
2 2
3 1.80
4 0
5 1.36
6 2.36
7 2.36
8 9.1
Luke51411
I'm of no help but I built a rissole that passes audio but no envelope detection. That reminds me, I need to troubleshoot that soon
Jimi, how far does audioprobing get you in the signal path?
It's distorted on the small IC but there is audio on the larger one. I don't have the odd in for. Of me, sorry.
Droogie
Worth mentioning that there are a lot of possible knob positions that result in no envelope in a properly working build.
Try the following to see if you're in business:
Top row, left to right (in case my labels/names are different):
Color—maxed; Decay—11:00; Attack—7:00; Sensitivity—1:00
"Moog" Toggle: Right
Intensity (left pot in "middle" row)—maxed; Blend—noon
Switches left to right:
Mode—middle; Range—rightmost position (low); Up/Down—rightmost (up); Bandwidth—leftmost (half)
Hope you get it working—it's a blast!
I replaced the 1458 and now my LEDs pulse again, but with the mix knob all the way up, nothing but static
Luke51411
Quote from: jimilee on May 14, 2015, 02:32:56 PM
Hmm I wonder if we are having different issues? The first LM1458 I had the led would change brightness in different switch positions and the pots would effect the brightness but the signal wouldn't. With the second one the pots don't effect the brightness, I didn't check the signal since it was late and my main problem wasn't fixed anyway but I assume it was still coming through since the 1458 is just the envelope detection part of the circuit... When I fired it up before the signal was coming through and a filter was being applied but not sweeping since the leds remained at constant brightness.
I'm thinking so, but I didn't want to hijack your thread. I audio probed, I have audio on one side of r2 only
Luke51411
Quote from: jimilee on May 14, 2015, 02:51:46 PM
I'll check that out as well. Honestly when I posted my previous response I wasn't sure which thread it was... haha
Quote from: Luke51411 on May 14, 2015, 03:16:15 PM
nice, if it isn't r2 check the one above it.
It was the effects loop, I have the enclosed jacks wired incorrectly. Now I gotta figure out these jacks....
