The Dirt Controller
Started by playpunk, April 26, 2015, 12:15:35 PM
playpunk
This is a pedal of firsts: first multi, first with smd jfets, first with optical switching, first collaboration.
It is an 8 ball into a supreaux deux. This is headed back to Dave on Monday. I don't know if I am going to put the supreaux deux into mine, I might put a color sound overdriver or something in instead.
5 offboard pots, 4 offboard led's, and a whole lotta Teflon wire.
Pics:
"my legend grows" - playpunk
The graphic design and etch execution on this are stunning and the knobs blend perfectly with the art. I really love this one. Board mounted pots are nice but not at the sacrifice of landing them in the right place on the exterior. Very well done!
playpunk
Thanks! I just gave this a full shakedown this morning.... The supreaux is sweet. Stacked.... Very nice
Dan killed it with the enclosure as usual -- nice job, you both!
Luke51411
Coda-effects
I really like the graduations around the knobs !
However... so much cable in this one !
Looks like spaghetti ^^
Jabulani Jonny
What a great multi.  I tried to buy one of his enclosures since I didn't have anything to trade.  They are impeccably done.
Jonathan
jprizz
That looks fantastic! Nice work.
playpunk
Quote from: Coda-effects on April 27, 2015, 12:23:32 PM
I am not a multi ninja like guru/sensei juansolo
Luke51411
Quote from: playpunk on April 27, 2015, 12:58:07 PM
I always end up making a wire or two too short and end up needing to redo them trying to make the guts look clean. There is a fine balance between too much wire length and not enough. At the end of the day, it works and sounds great! Thats what really matters right?
playpunk
Quote from: Luke51411 on April 27, 2015, 01:01:36 PM
Yeah, that's what I tell myself. I probably should have told dave that I was planning on using the optical switching system, but I hemmed and hawed about it, and only finally decided to do it after I got the enclosures.
Even so, the dual LED's look sweet when they light up, and both circuits are noise free, despite all of the wire. I used silver-teflon wire, which is super super strong and slippery, but not the easiest to  strip, and so I'm kind of leary of stripping it too much after it is soldered to the board.
I might have been able to make this cleaner, but after the delays and frustration of dealing with an uncooperative pcb, I was kind of out of patience.
If (when?) I make another multi, I will most likely use all board mounted pots, and plan even more carefully. It seems to me that Multi's are adventures in compromise anyways - even juan's impeccable builds use solid core wire (which I'm not comfortable with) and other tricks to stay so clean.
Dave's graphics on this one are absolutely spectacular, and way way way way
way
way
way
cooler than anything I ever would have come up with, so I'm happy with the neatness compromises inherent with five off board pots, four off board LED's, and angled PCB's.
I  enjoyed the collaborative process on this, and I hope Dave enjoys the finished pedal as much as I have, despite the messy guts.
tenwatt
Not too bright....
Dminner
Quote from: playpunk on April 27, 2015, 01:56:10 PM
Messy guts don't bother me.  I plan on using it, proper functioning is all that matters.
Thanks again!
Dave Dan  ;)
rullywowr
Wow, that is most excellent!  Love the enclosure and theme.  Well done all the way around - both of you.
Shrtyska9
Man! That is awesome! Hell of a job guys!
Richard
