TH Customs Supreaux Deux Help!
Started by playpunk, April 24, 2015, 08:51:59 PM
playpunk
Ok will do.
"my legend grows" - playpunk
playpunk
Well sweet mother of pearl.
I didn't have continuity between r5 and where it ties to ground (TP 2), so I hardwired it in.
Retested and still no signal. F-word.
Kept running through the rest of the schematic testing for signal, and found that there was no signal at either side of c4. Replaced it- still no signal. Found that there is no continuity between c4 and r14. Should I bother trying to hack another hardwired connection in? I will check for continuity with ground from both sides of r14 first....
Has anyone built the Blue PCB version of this successfully? I have not abused this board, reflowed the solder once or twice, but not enough to lift any pads or anything.
I am just having so many troubles with this board.
That's just weird. Are you getting the right voltages now at least?
playpunk
Yes, I can get 12v at each transistor.
I am going to attempt my own layout that provides for smd jfets as well as thru hole, and 5mm trimmers
playpunk
Quote from: midwayfair on April 26, 2015, 09:04:03 PM
I forgot to check GSD on t2, but I will do that later today and report back.
This thing is driving me nuts.
playpunk
Quote from: playpunk on April 27, 2015, 02:20:53 PM
I checked a day or so ago - and I have wacky voltages - 12ish v on each leg of the transistor and the trimmer.
