Kingslayer 2 -I hate asking for help
Started by MarcFive, April 09, 2015, 07:30:13 AM
MarcFive
Came back to this after a year, because I just ordered parts to build this pedal for some friends, and I still haven't figured out what I did wrong with this one. I know I've checked every component value, even measured the components that allow being tested 'in circuit.' Just installed another set of chips.
Pedal turns on, tone control sounds awesome, volume works,(fooled me into boxing it), fat mod works, everything else, gain, bypass buffer, clipping switch is not functioning. The gain knob fully counter clockwise induces a little whine, otherwise has no effect.
1044 SCPA Voltages are as follows:
1. 8.75v          8. 8.71v
2. 5.05v          7. 5.24v
3. 0                6. 3.84v
4. -3.59v         5. -8.53v
TLC 274:
1. .4mv           14. -2.9mv
2. o                13. -.1mv
3. .1mv           12. -0
4. 8.84v          11. -8.58v
5. 0                10. -0
6. 0                  9. 0
7. .1mv             8. 3.0mv
I'm hoping these voltages just scream out at someone.
I had the board out of the box and went over the entire board with a loupe and hit anything that even looked  the slightest bit not perfect. I am suspicious of the dual gang pot, but I can't see how that would affect the tlc 274 voltages.
Marc,
There was an update to the doc last year suggesting that R28 be replaced with 150R or higher. You could do that, or swap in a different quad amp like the TLC2264 or TL072 if you do not want to go through the trouble of desoldering. Either will solve the problem...your voltages are fine.
MarcFive
Thanks Brian,
But I don't think we're on the same page. I see the 10R/150R change, but I thought I should be getting 18v somewhere in that quad. I'm not getting any gain/clipping or buffering. But if you think those readings are good, my only guess is the 100K dual gang, I don't get any resistance change on the clean side sweep .
TGP39
Hi Marc. You are getting ~18volt swing on your quad.  The TC1044SCPA is taking in the 9 volts on pin 1 and pushing out 9 volts on pin 8 AND -9volts on pin 5.  There is your 18 volt differential.  I hope this helps.
Steve.
Like Steve said, the voltages are correct. The problem is that the IC is pushed a bit beyond it's capacity which is why I changed the limiting resistor as is seemed to solve the problem. But, an IC swap also accomplishes the same thing...the only difference is whether or not you feel one IC is better than the other. Personally, I really like the 274 in this circuit which is why I put it in the BOM even though the design pushes it just out of spec. But, the 2264 or 074 also sound fine.
MarcFive
Quote from: TGP39 on April 09, 2015, 11:07:53 AM
Steve.
Thanks Steve, I thought that was the case, but I was using the Sunking II as a reference. So I guess the Sunking is running one TL072 @ 24v and one @ 12v(?). When I originally measured the Sunking, I got something close to 18v and figured I'd have the same sort of finding on the Kingslayer circuit. I had in my mind the pedals ran at 18v. I guess it's time to start deciphering some Data Sheets.
MarcFive
Quote from: madbean on April 09, 2015, 12:17:24 PM
Thanks Brian, Just on a hunch I slapped a waning battery on the pedal as opposed to my Voodoo Lab supply, but that didn't seem to help much. (Reasoning the 150R resistor was dropping the supply voltage a smidge).  I measured the dual gang pot on me Sunking II and it has the same sort of odd readings in circuit as this one. So I'll swap the resistor and report back.
TGP39
Hi Marc. To my knowledge, you can't measure a pot in circuit the same way you can't measure a resistor in circuit. Anyone, please correct me if I'm wrong.
Steve.
MarcFive
Quote from: TGP39 on April 09, 2015, 09:42:42 PM
Steve.
Well, if you look at the schematic of the dual gang pot the clean side has a parallel 1.5K resistor. This seems to be what my meter reads regardless of where the pot is adjusted to. It also has a resistor and cap in parallel but I think the cap pulls it out of the equation.
The dirt side of the pot doesn't have anything attached in parallel that isn't broken up by the op-amp, so it reads like it should read.
As far as measuring resistors, I find most can be read, but there is the odd circumstance where I've pulled a resistor only to find it was indeed just fine. In fact the only two bad resistors I've ever come across were in a Handmade Bluesbreaker pedal an old friend asked me to look at. The board was perf board and the wiring looked like a birds nest, I think he used enameled pickup wire or something. It was just dumb luck I figured out what was wrong. The only electronics I had engaged in up until that point was building a Pete Cornish buffer. Come to think of it, that's what started this whole mess, I didn't want to pay $800.00 for $3.50 worth of parts... Now I have come across some Carbon Comps that I believe were rejects, but thats another theory.
Caps seem to have a lot more happening, but I'll tend to check them before install since they vary so much.
I've only been doing this for a very short amount of time, but these are my observations.
mgwhit
What value is your C9?  It should be 390pF, but it's the same size as your 390nF C5.  If you have a 390nF in C9 you're letting way too much signal bypass the negative feedback loop resistance, which would kill all of your gain.
MarcFive
Quote from: mgwhit on April 10, 2015, 02:24:36 AM
And the winner is... OMG, do you know how many times I've gone through these... I seriously need to buy you a beer!
Well done.  ;D
Swapped the errant cap and nothing. Swapped the IC's and got gain finally  but glitchy when I'd dig in a little. Then it just started sputtering.  Gonna put it away now before someone gets hurt.
mgwhit
Quote from: MarcFive on April 10, 2015, 03:41:13 AM
Well done.  ;D
I'm happy you're happy, but I wish that would have actually fixed your problem. ;)
I take it you switched to a quad op amp with a higher voltage rating?
MarcFive
[/quote]
[/quote]
No, same ones. TC1044SPCA, TLC274. I also noticed whine with the gain all the way down. I've got parts coming for a couple more of these, I ought to be able to get one working and then have a reference. I'll have to order a different quad and see what that does. I didn't realize there was an issue, I built this one year ago and then health issues popped up , but I seam to be bouncing back.  So I missed all the discovery.
TGP39
Glad you are feeling better Marc. Keep plugging away at it, you'll get it. And don't ever feel uncomfortable asking for help here....we all need it from time to time.
Steve.
solderfumes
I built one of these (on perfboard) and I too get whine when the gain pot is all the way down.  I used two separate pots for the dual-gang pot, so it's probably not a problem on the clean side.  Does anyone have a remedy for this?
