Change Switch for amp footswitch.
Started by morelius21, June 12, 2011, 03:38:06 PM
morelius21
Hello,
I have a Fender Footswitch CHAN-DRV and one footswitch is broken. I want to change this switch but i don't find it anywhere. The original switch is a Carling mexico 0822R and this switch has three pins, spdt on/on. I search for another switch to replace but can't find it.
Someone can help me?
Thanks
MOrelius
Any Double Throw footswitch will work. You don't need to use all the poles on a switch. So for example, you could get the cheap X-wing Taiwan DPDT switches and just use one side, or if you have some of the blue/white/black 3PDT switches we all use for true bypass you could use one of them as well.
