Bass preamp/DI box
Started by alanp, March 08, 2015, 02:59:20 AM
So I'm thinking of doing a pre-amp/DI box for bass, to go bass-box-mixer.
Would a ROG Ginger plus Balanced Line Driver from TH Customs do the trick? (Thomas, the THC acronym tends to make me giggle a bit :) )
And what other boards would be a good idea in front of them? Maybe a fuzz?
thesameage
BYOC is down, but look in completed builds because someone build pretty much exactly this...
GrindCustoms
One thing i'd do is put a loop between the effect before DI and DI, in case you'd want some modulation, delays... anything that you'd like to get to the PA aswell.
Good point on the FX loop.
I've been having fun with my Squier Affinity P-bass on Rocksmith, my left hand hasn't gotten used to stretching for bass frets, though!
GrindCustoms
Quote from: alanp on March 08, 2015, 07:10:18 AM
In real life situation, when you can't reach.. you simply do a blurry slide up the neck.. always works, it's just bass after all.  :P
Seen that too many times with sloppy bands.  ::) ...end of derail.
Willybomb
QuoteBalanced Line Driver from TH Customs
I've used this in two builds now and I'm really happy with it.  Works as advertised.  For the bass preamp side of things I like the NE-1.  Paulinthelab has a vero layout, rullywowr put up a build report with a pcb he'd designed for it.
neve1272
i have wanted to build something like this for the wife for some time but with a good compressor too
have some boards stuffed and waiting for more time / parts
Kip
I'm in the planning stages for one of these, but I'm not 100% sure of what I will include.  This is what I have so far: one of rullywowr's NE-1 PCBs, a TH Custom line driver, a GPCB Paramix, and 2-3 compressor PCBs to pick from.  I also ordered a Bass Driver DI / Sans Amp from Brejna and a Fluffgirl from Rej.  It will take a while to sort this out.
brejna
I am currently working on the 3 in 1 bass pedal for my band mate. Carl martin compressor > Blower box > Bass driver DI. I am waiting for blower pcbs, enclosure and few components to arrive..
Quote from: patrickbrose on March 08, 2015, 02:30:48 PM
Quote from: thesameage on March 08, 2015, 06:59:56 AM
http://byocelectronics.com/board/viewtopic.php?f=8&t=51533
Yup that is my build. Works as you would expect. Any questions?
Can you walk us through the wiring, that's genius. I think I get it but I'd like to know for sure.
GrindCustoms
Shameless prostitution, i have fully populated, tested Thomas Line Driver for sale in the BST, all built with premium components, using audiophile grade caps for the balanced out.
patrickbrose
Sure,
Input jack goes to true bypass switch with the ginger on the true bypass. After the TB the out of the TB switch goes to the tip of the output jack and to the center lug of a SPDT center off toggle. One half of the toggle goes to the line driver DI, the other half to the headphone amp. So possible combinations:
1. Bypass everything
2. Ginger only to output in front
3. Ginger-->DI
4. Ginger-->Headphone amp
5. DI only
6. Headphone amp only
7. Ginger-->DI and front out in parallel
8. Ginger-->Headphone amp and front out in parallel
Only combination you can't do is both the DI and Headphone amp at the same time.
patrickbrose
3. Ginger-->DI
7. Ginger--> DI and front out in parallel
