newbie
Started by foochild, February 24, 2015, 04:21:56 PM
foochild
Hello, I'm new to the site. Right now I'm trying to build a Grind Customs Chimaera and I am having trouble finding good instructions on the wiring.  Any comments would help.
Thanks
Stomptown
Welcome!   Here is the madbean standard wiring diagram that most people around here use for their wiring.  It will work fine for the Chimera or any other +9V effect pedal using true bypass.  If you do not want a battery, just ignore that part of the wiring diagram.  Not using a battery would also mean that you could use a mono jack instead of a stereo jack if you want (a stereo jack will still work but is not necessary).
http://madbeanpedals.com/tutorials/downloads/StandardWiring_MBP.pdf
Hello,
Rej happens to have his very own area for Grind Customs products here on MBP. Take a look here and try posting a new thread and I am sure he will help you out.
http://www.madbeanpedals.com/forum/index.php?board=73.0
Welcome BTW...  ;)
What they said.
Welcome!
foochild
Thanks! I really appreciate it.
The chimaera is a little different if you don't wire it true bypass though. :-)
Stomptown
Quote from: jimilee on February 26, 2015, 02:28:36 AM
oOps!  I completely forgot about that!
