Reuse Enclosure After Bad Etch
Started by Dulouz, February 23, 2015, 07:27:33 PM
Dulouz
Hey Guys!
I had a particularly bad etch a couple weeks ago and I'd like to salvage the enclosure.
Do any of you reuse enclosures after a bad etches? If so, any tips on getting them ready to re-etch?
Sanding materials or techniques?
Stomptown
Do you have a palm sander?  If not, it can be pretty hard work depending on the depth of the etch.  I just got the control labels backwards on an etch this weekend and decided to start over with a new enclosure due to the depth of the etch. as far as getting them ready for a re-etch goes, I would suggest 60/100/120/240 grit sand paper followed by 400/600 wet sand.  I would actually suggest this process for any etched enclosre; not just a re-do although you can probably start at 100 grit instead of 60.  If you have a palm sander this only takes about 10 minutes.  If not, it's pretty hard work! Did you sand the enclosure in the first place?  If not, you will not get a good etch.
Dulouz
Thanks Jon!
Yes, I did sand. It just was a bad print on the transfer. I tried it anyway, but wasn't happy with the results.
I'll give the method you suggested a try.
billstein
You could always use a faceplate on that particular box.
Stomptown
billstein
Quote from: Stomptown on February 23, 2015, 08:39:27 PM
Quote from: billstein on February 23, 2015, 08:31:06 PM
Not a bad idea!
Unfortunately I learned this through my epic fails at trying to etch boxes. I'm much to lazy to sand all the metal off, so I hide it instead. A few of my boxes with faceplates are covering up massive shame. :)
could use a grinding wheel...but a face plate would be far less work.
Lots of really sharp, etched copperclad faceplates out there, be a great save!
Quote from: davent on February 23, 2015, 10:07:59 PM
That's what I've done in the past.  Not with copper, but a face plate can save the day.
I actually have a few mis-drilled enclosures that I need to do this with. Might be time to order some black and blue copper clad.
VanDerchuck
Quote from: flanagan0718 on February 24, 2015, 12:22:25 AM
I'm glad I'm not the only one. My first few, ok maybe almost half dozen, enclosures ended up atrocious. I've since gotten better at drilling the marked spots. However, I still make stupid tired mistakes from time to time. So I'm prepping my first etches with face plates first. And then doing some enclosures. Prepare for the worst.
My $.02 is worth exactly that...
Dulouz
I went down and picked up a hand sander and some more sand paper. The bad etch came off in about 2 min. with the 60 grit. I'll proceed with the rest of the grits and get these things ready to re-etch.
Thanks for the suggestions guys!
