Audio Magic with Bipolar Guitar
Started by Mojo Fandangle, February 16, 2015, 09:02:00 AM
blearyeyes
Quote from: juansolo on February 17, 2015, 11:55:07 AM
Think how much better it'd work if you fitted that into the guitar in the lower horn area of say a tele... I reckon with some refinement it'd be genuinely useable.
Me thinks the same.
Put it where you could tap below the strings and use thumb and fore finger for playing licks. Oh yea it turns off in the middle..
OK a glove with touch sensitive fingertips!
RobA
Four or five touch sensitive pads on the body of the guitar that then went to delay lines and/or filters and were mixed together at the end would be pretty killer. You might be able to do this pretty easily with a Kaos pad controller, but it would be better if you could program it yourself. Add in the sustainer/harmonics control stuff from Vo and it could be pretty amazing to play with.
