true bypass presents new issues.
Started by Diocide, January 29, 2015, 03:22:22 AM
Diocide
So I recently finished up my pork barrel from madbeans, which is a Boss ce2 clone.
I plugged it in today and I've run in to a problem. I wired the Pork Barrel for true bypass and placed it as the first pedal in my fx loop, exactly where my CE2 was. Now all my delays and reverbs are after it, so it goes Pork Barrel, Dispatch Master, Echorec, Ibanez DE7 back out to the fx return.
Now when I turn on my dispatch master, I get a HUGE volume boost. The enforce does it too, but not as bad.
Is this because the CE2 is buffered and the PORK barrel is not?
Stomptown
I don't have the answer, but is the pork barrel on or off or either when the boost occurs?
Diocide
Stomptown
In that case, does it happen if you remove the pedal from your chain?  If so, that would seem to indicate the Boss CE-2 is affecting your signal and I would guess it is the buffer.
