Soft BB preamp
Started by panchokunstmann, January 25, 2015, 08:32:22 PM
panchokunstmann
Long time without update.
is a BB Preamp slightly modified:
in the diode # 1: The modification is an old diffuse green led  versus 1N4148 diode. the green led sounds less compressed, more organic and less saturated but the 1N4148 diode also has its charms.
Well, I used a JRC4580D that also delivers a less compressed and more organic sound that JRC4558.
Also I changed the curve of potencimeters (Vol and Gain) for a logarithmic curve, I think it works much better than linear curve.
outside:
yellow led :
inside: ( as always, I'm not proud but I think I'm improving )
regards
Hogharry
I really like the way that you tweaked it to how you wanted it to sound.
...and then of course I've got this terrible pain in all the diodes down my left hand side...
Clean & simple. I like it!
1N914 and ilk are my least favorite way to clip a signal. I bet the LED sounds great in there.
Luke51411
Simple but elegant an killer sounding I would imagine. Great build.
Coda-effects
Very clean ! I like it a lot with this color scheme
JoeDorcia
Oooo, very tempted to try the LED clipping in mine. Might socket and try a few different colours etc. Was it a 3mm diffuse you used?
Making noise since 2001... If only I knew what I was doing
Instagram.com/Twitter - @JoeDorcia pictures and pretentious ramblings about my son, coffee, food, pedals and guitars...
panchokunstmann
Quote from: JoeDorcia on January 26, 2015, 12:41:29 PM
Thanks to all, really is very pleasant forum   8).
It is a 5mm led, I'll try different colors this weekend and some diodes that I have.
I'll tell you how everything is going
The pedal really sounds great, I love it
