NomNom 2015 LED question
Started by mcallisterra, January 19, 2015, 12:37:35 PM
mcallisterra
I have just finished building the new NomNom, rocked it before boxing it with the JMK style test box (without the LED hooked up) and all was fine, but the LED isn't working now that I hooked it up with the whole enclosure.
Before I go about troubleshooting for an error I wanted to make sure I understood the build doc correctly. If you want an always-on LED, do you omit R29 and leave the LS pad empty, and hook it up as per the diagram in the doc? It reads that way but I wanted to check.
Thanks!
mcallisterra
Never mind - found a small solder bridge between the + and - LED pads on the PCB. Working perfectly now!
