Sunking POP!
Started by gtr2, May 30, 2011, 01:38:28 PM
Jimihendrix1987
Hi Brian ! Every voltage reading is allright in IC3, but not in IC2 and IC1 (only the pins I said, the other ones are ok)... And the 2 27k resistors are 27k !!
What would it be??
Jimihendrix1987
Solved  ;D
The mistake was an incorrect false contact between c7 and r14. Suprinsingly the effect sounded quite well (as usual) but there was a POP engaging effect, which stopped the sound one second !
Thanks man !  ;)
bigmufffuzzwizz
Quote from: Jimihendrix1987 on July 10, 2011, 07:31:31 PM
Solved  ;D
Thanks man !  ;)
I'm curious how you figured this out. Especially since C7 and R14 don't touch!  :)
Jimihendrix1987
[/quote]
Haha ! Because I was cheking everything up and I realised that I used a big cap there, which lead was touching a little bit the R14 in the components side... I was going mad, because everything was allright, and when I realised that I start laughing !
