A mini-multi - 5150
Started by juansolo, January 16, 2015, 07:09:06 PM
I was thinking this might be tight when I decided to put it into a Camden Boss small box (they're shorter and more shallow than a 1590B, fractionally wider though), well tight is an understatement. The gutshot is genuinely as far as you can open the box and when it's together there is no wiggle room at all in anything. Not a sausage.
In there is a Grind Customs Octane (formally Inline8), a very 80's sounding distortion, with a Script Phase 90 clone. The I8 is actually my old 1590A rehoused and the P90 is one of Pickdroppers 1590A boards also.
I get asked about the light tent a bit and I've started assembling new lights for it (long story as to why this is being such a ball-ache) and they're still missing some reflectors that I'm going to have to get. But here you go, a table top light tent and a couple of lamps.
Tight is an understatement...
The jacks fit between the pots so tightly that they don't need bolt on them and all three (two pots and one jack) had to go in in one go for them to get in there. Wiring occurred later.
Madly the Inline 8 is pot mounted on the level pot with just fits underneath the two stomp boards.
The jacks have their pins bent flat and the P90 sort of sits in the gap. The caps just clear the path of the in plug, one of the caps is pressed against the I8's IC, and everything was made ultra low profile to fit in the gaps available.
It had to be built in stages and tested as it went along as it's pretty much impossible to take apart now. I may have gone too far with this one... ;)
rullywowr
Tighter than a nun's....
...well uh nevermind.   ;D
That is seriously some great wiring there!  Love the decal and layout as well.
-Ben
I highly approve of this build.  My kind of madness.
very awesome, thanks for showing your light set up too, even if not done.
Hogharry
My that's tight! Surprised you didn't try to get a plate reverb in there as well. I bet it sounds good.
Nice to see that your lights are working.
...and then of course I've got this terrible pain in all the diodes down my left hand side...
Nice seeing your photo setup. Your pedals always pop off the screen, it's not only your eye catching designs but the quality of the photos themselves. Great looking pedal and great photos!
Awesomesauce! And a tight one (did anyone mention that yet... ;)) for that matter... Looking good and great to see you photo booth thingy...
sonarchotic
Quote from: davent on January 16, 2015, 11:22:31 PM
Yeah.
I don't think there's any way Id've tried this one, either. Smashing!
GrindCustoms
Challenge accepted!
That looks like lotta fun! ;D
TGP39
Love it, Love it, Love it.   You should have stuck a lump of coal in there....you'd have a diamond by next week.   ;D
Beautiful artwork and mad skills putting this together.  I like your photo set up as well.  Cheers.
Steve.
Quote from: GrindCustoms on January 17, 2015, 04:29:08 AM
Challenge accepted!
FWIW I consider a 125B to be cheating ;)
GrindCustoms
Quote from: juansolo on January 17, 2015, 09:20:42 AM
Challenge accepted!
I consider a 1590B as a fair contender  ;)
