Taptation / PT2399 Build?
Started by blearyeyes, January 03, 2015, 12:04:41 AM
blearyeyes
Has anyone built a Guitar PCB D'lay with the daughter board for the Taptation chip set and had it work properly?
There are some "The LED blinking does not match the output of the delay" complaints.
If anyone has any information regarding the Taptation / 2399 working or not working please let me know.
I have two of them here and would like to build them up but..........
01101000 01100101 01101100 01110000 00100001
I built one several years ago - right after Barry released it I think.  Mine works perfectly with regard to the tap tempo and the LED.  I do recall that I couldn't figure out what the sweep toggle does.  If you want I can pull it out over the weekend and verify that.  I haven't used it since I built my Multiplex Echo Machine.
blearyeyes
Multiplex Echo Machine have tap tempo?
Quote from: blearyeyes on January 03, 2015, 02:09:53 AM
No, but I only have room for one delay.
blearyeyes
Sweep is supposed to be modulation.
