Zero Point Micro II no delay sounds
Started by Aryk, December 10, 2014, 10:26:40 PM
Aryk
I get signal just no effect. Pot don't seem to change anything either. Here's my readings:
TL072:
1. 4.54
2. 4.54
3. 4.54
4. 0
5. 4.54
6. 4.54
7. 4.54
8. 9.0
PT2399:
1. 4.49
2. 2.22
3. 0
4. 1.05
5. 4.31
6. 0
7. .05
8. 4.14
9. 4.24
10. .66
11. 2.22
12. 2.22
13. Same
14 same
15 same
16 same
Regulator:
VI: 9.09
G: 0
VO: 4.48
Also my regulator is pretty hot like could burn yourself if you held your finger there too long.
Any thoughts?
Thanks,
Aryk
copachino
IMO pin 4 must be 0v as pin 3, its grounded internally via 10 ohm resistor check value near pin 4
Aryk
Yep pin 4 is at 1.05 not sure what might cause this
copachino
Quote from: Aryk on December 11, 2014, 02:21:34 AM
Hace ypu tried another pt2399???
Aryk
I have yes. What other parts are connected to pin 4 that would allow voltage to get to it?
copachino
Pins 4 - 10 are all off. Here's what you should be getting:
1. ~5v
2. 2.5
3. 0
4. ~0
5. >=2.5
6. 2.5
7. <1
8. <1
9.-16. 2.5
The fact that your regulator is hot means something is wrong. Are you using an LM78L05?
copachino
sounds like a bad reg or bad IC to me, pins 5 to 8 have voltage surge direct to the reg, if not supplied ok, could be reg or a jumpered pad somewhere
Aryk
I'm using an LM78L05ACZ and have swapped out the regulator and IC with no change
copachino
Quote from: Aryk on December 11, 2014, 07:46:59 PM
can you post photos of the board??
Aryk
Here you go
copachino
first i see you are wiring cables of pots upside down... why??
Aryk
It's to fit it into the enclosure they aren't upside down
Aryk
Or at least are wired correctly.
copachino
i saw it now its right wiring on the pots, have you tried to move de delay pot??. also the best its to make a probe and on the IC(pt2399) input give a shot. also once happened that the input was grounded and the output too, if that its so, the you get only bypass output
