Adding a dry/kill switch to Moodring
Started by pogart, December 08, 2014, 11:26:54 PM
pogart
Almost finished the moodring board and looking ahead I realized I am unsure of how to wire up the kill/dry switch. Still fresh on building pedals so any advice would be greatly appreciated : )
Thanks
POGART
Hey Pogart. It's not a terribly complicated wiring, and if you check out the wiring diagrams in the build docs, you'll see that it's included there.
Essentially, you'll need a spdt switch. Wire the square pad to the centre lug, and the other pad to one of the sides. Done.
Even a dpdt switch will work. You just need a switch to make it work, and make sure that the two break connection one way, and make connection the other way.
pogart
#2
Cool thanks Jacob, is that the same for the little toggle switch (dry/kill switch at the top of the enclosure drill template for the moodring?
