CM plexitone power mod?
Started by petesz, May 18, 2011, 05:56:52 AM
petesz
Hey all,
So my friend has a Carl Martin Plexitone that he wants to be able to run on a normal 9v adaptor. I agreed to do the mod for him thinking it would be a straightforward case of using the road rage as a charge pump to power the 12v, but I was just reading the thread over at freestompboxes and it seems it's a bit more complex than I originally thought..
Is there a way to use the road rage to get both +ve and -ve 12v power at once?
Or has anyone done or heard anything about this mod? I know This dude does it: http://www.hugeracksinc.com/forum/viewtopic.php?f=1&t=75535
Would anyone be willing to help me out on this?
stecykmi
easiest solution is to buy a 12v power supply, then use the roadrage (with a suitable chip to handle that voltage).
otherwise, i don't really know much about them, but there should be a voltage regulator that will step up 9v to 12v. then it's easy enough to use a roadrage, as above.
petesz
Hmm so maybe I could use a roadrage to step up from 9v to 12v, then use another road rage to get the +/-12v?
I think instead of using two Road Rage boards, you should learn a little bit about how charge pumps and either create a layout for a charge pump that will take 9V in and give you +/-12V out...
petesz
Ok.. so ive done some reading.. but still not sure how I can do this. I think my problem is i dont really understand bipolar power supplies..
Might be easier to use a 12v power supply and then just use the road road to get the bipolar supply..
cjkbug
Quote from: petesz on June 02, 2011, 12:06:43 AM
doesn't that defeat the purpose of what you are trying to do?. jkokura was right. stdy up somemore and experiment on a bread board till ya crack that nut. then wright back and tell everybody what ya did. you'll be a hero.
stecykmi
Okay, there is likely a better way to do it, that uses fewer components, but this should work:
Use a 1044 to step up the voltage to ~18v. Use a voltage regulator (7812 is the p/n) to bring the voltage to a even 12v. Then use a second 1044 to make a split power supply at +/-12v.
If you're using a roomy enclosure, it should be okay. Rather inefficient since it's using 3 voltage converters, but nothing's perfect I guess.
