Aquaboy
Started by MattL, May 12, 2011, 05:29:55 PM
MattL
I notice in the plans for the Aquaboy there's no switch wiring diagram. Is it the same as anything else on here, or can I use the easy Tonepad method? I tried the latter on the Thunderpuss, and it didn't work, though I don't know if that was the problem. Thanks
sgmezei
On Madbeans Projects  their is a link to the new "global" wiring diagram in the top right corner.
MattL
Thanks a lot! One last question...I'm guessing that diagram is no good for things like the Sunking right...since that has the resistors on the switch?
The documents make it pretty clear when it's a 'buffered' bypass, like in the Darkside and Sunking projects. Most projects use the generic true bypass options that are available at that link. It'll be clear when it isn't.
