Glitterratti Jumper Question
Started by insomniac2295, May 12, 2011, 03:11:41 AM
insomniac2295
Hey, first time poster. I'm building the Glitterratti (manufactured version) and notice that there are some extra holes in the board by C4 and C11. Am I supposed to put a jumper here?
Those are PCB vias. You can just leave them as is. They connect the top and bottom layers where there are no component pads.
insomniac2295
#2
Thanks! Also, I can't find any 19K resistors. Would 19.1K work for R10?
I would use it in your shoes. It's a little outside 5% tolerance, so see if you can measure all the 18K resistors and use one that's 18.3-18.5. That would get you closer.
insomniac2295
Yes that's well within the 1% tolerance mark, very good to use.
If you want to get real DIY, take a 20k and an Xacto knife and scrape some material off the resistor body.
bigmufffuzzwizz
Quote from: madbean on May 12, 2011, 06:45:14 PM
Why you gotta pull our leg..
