All in one Bass Pedal
Started by PhiloB, October 26, 2014, 01:04:53 AM
PhiloB
I put a used Squier Classic Vibe Jazz Bass on hold and will pick it up on Monday.
I will be playing it in a small room with a small PA.  I would prefer not to buy an amp.  It would be very convenient to build a pedal with a direct out to plug into the PA.
What projects/effects would you recommend?
((I am not a bass player, but someone needs to play;)  I have limited knowledge on how to get the best time, no tip is too simple))
PhiloB
Quote from: PhiloB on October 26, 2014, 01:04:53 AM
That should have read 'best tone' not time.
Thanks Cody!
I built a transformer less direct box for a guy, I have a 4 in 1 with an overdrive, a green Russian, an phaser and a delay. Covered 90% of my needs.
Also a ginger is great for an amp in a box simulator.
mremic01
There's a Sansamp BDDI clone project out there (though I suspect the original tracing comes from the Behringer clone): http://www.diystompboxes.com/smfforum/index.php?topic=88617.0
I just put one together with a Compulator in the same box. Makes for a great all-in-one, and the Sansamp stuff sounds pretty good when you're running direct.
PhiloB
Thanks mremic01!
Willybomb
#7
Here's mine:  Compressor, fuzz, preamp, 1/4 inch and balanced XLR out.  I don't really feel that a cab sim is necessary for bass personally.
http://www.madbeanpedals.com/forum/index.php?topic=15890.msg
Quote from: Willybomb on October 26, 2014, 02:47:45 PM
Yeah, but you can....you don't have to, but you can and that's what it's all about. 😜
Jopn
I'm in the process of building one of these into a 1590DD with a DI and cab sim:
http://www.albertkreuzer.com/preamp.htm
Willybomb
QuoteYeah, but you can....you don't have to, but you can and that's what it's all about. 😜
Sorry, I forgot.
the3secondrule
catalinbread SFT is my go to for bass dirt at the moment. That, and a klone. And a modified rat :)
Anyway, if the SFT interests you, Jubal does a pcb for the SFT (lamprey I think) if you want a fabbed board, or get haberdasher to etch a fault line for you...
PhiloB
Thanks for the tips.  You guys have laid out some good options.
