pop pop cave dweller
Started by copachino, October 21, 2014, 01:29:20 AM
copachino
i think this its the most problematic pedal i have ever build, i have a brand new problem the pop...
it just happen when i stop using the pedal for a while or has been bypass for some time, after the first pop i can press bypass many times, but never return until i leave for a while off, so i was thinking may be the led??, i have a 2.2k resistor on that(as i always do) but could it be sucking too much power that, when its off for a while sucks to much power the first time it turns on???
Mine does that same thing, I just turned it on and off before rehearsal or a show. Never was an issue after that.
copachino
Quote from: jimilee on October 21, 2014, 02:03:08 AM
so its a thing of the pedal itself?? umm i kinda rare, but i think i have to do the same as you do, hope i never forget to do that
I had this problem with one build and it ended up being a shoddy electrolytic cap. Just a thought.
copachino
Quote from: selfdestroyer on October 21, 2014, 02:12:26 AM
i could try to repalce all electrolics, maybe using a electo instead of a tantalum its the problem
