BS250 orientation
Started by brejna, October 19, 2014, 04:43:20 PM
brejna
Hi guys I am building sunking 2 and deadringer 2 and both of them have BS250 transistor. I bought only two of BS250 and I don't want to burn them, so how can I check pinout of them with a multimeter?
Thanks
Brane
Scruffie
Just check the datasheet, it'll show the pinout.
Works at Lectric-FX
brejna
Quote from: Scruffie on October 19, 2014, 04:46:01 PM
I've red few of them, but these look differently. They don't have classical D shape, and marking is on the opposite side of what I am use to (EBC and DGS transistors).
brejna
Can't download a datasheet from your supplier? Is there a manufacturer's identifier?
brejna
#5
Quote from: davent on October 19, 2014, 05:12:23 PM
Unfortunately they don't support datasheet on their website..
http://www.musikding.de/BS250_1?lang=eng
Quote from: brejna on October 19, 2014, 05:17:10 PM
The pinout they show looks to match the pinout on Brian's build documents for those two pedals.
As to how to identify Mosfet pinouts with a DMM i did find an explanation by R.G. Keen at diystompboxes but my foggy brain is not allowing me to process the info at present.
Edit; duh, forgot this.  http://www.diystompboxes.com/smfforum/index.php?topic=76438.0
brejna
I will try as it is shown on the layout.. If it burns I know what to do :D
Thanks for help
Cheers
brejna
#10
R.G. says: ''For MOSFETs. The gate never conducts to any of the other pins. The substrate diode conducts the reverse direction of the channel, so for an N-channel, the substrate diode conducts with anode to source, cathode to drain.''
Is this valid for P-channel? or it is opposite?
I've tested BS170 and it is correct pinout like in the datasheet. Also it gives me same pinout for BS250, so this should be ok?
