Less Delay in Mix?
Started by GammaFlex, October 08, 2014, 02:20:57 PM
GammaFlex
So I've been building some more delays as of late, and I'm wanting to make one that has less of the delay on the mix knob. I've been using 100K pots, would I get less delay in the mix if I upped the value to something like 250K?
kothoma
Quote from: GammaFlex on October 08, 2014, 02:20:57 PM
The mix pot typically is just a voltage divider.
But following are usually a cap and a resistor feeding the wet signal into a mixing op amp.
Increase that resistor and your max mix level will decrease.
