Moodring regulator
Started by Stig, September 16, 2014, 07:26:32 PM
Stig
Hi all.
I am about to make a Tayda order for the Moodring parts + some bibs and bobs.
The problem is they don' t have the LM78L05. Or that is they do, it´s just an smd ic. Guess that wont work.
Are there any other that will get the train in the station... As you say   ;)
Any help appreciated.
EDIT:
There are this little bugga:
http://www.taydaelectronics.com/l78l05acz-l78l05-78l05-5-volts-100ma-voltage-regulator-ic.html
This is the same as in the tenebrion. Is this it?
Shrtyska9
As far as I can tell that's the regulator you are looking for.
Richard
Richard
I would say the same. There are different packages out there. you need the 3pin version (TO-92), so this seems to be the right one.
Stig
That was fast. This must be it then.
Thanks for your fast replies and help.
