Who designed the sea flea?
Started by jimilee, September 02, 2014, 06:03:21 PM
Quote from: lincolnic on September 03, 2014, 03:01:20 AM
Check the voltages on your regulator and make sure they're what you should be getting. Off the top of my head I think you should be seeing 5V at pin 1 of the PT2399 if that's an easier spot to measure...
That's all good, that was my thought too. The only other thing I can think of is I used a little extra flux on some if the ground connections, they seemed a bit stubborn. It's not unheard of for flux to cause issues.
I have  audio, just no delay and a hot regulator.
Quote from: alanp on September 03, 2014, 03:29:12 AM
Tried a different PT2399?
yep, I may need to try a few more I suppose maybe?
Pin voltages. I'm using a battery so VB+ is 8.1
i-4.9
2-2.3
3-0
4-4.9
5-4.9
6-2.3
7-0
8-4.5
9-4.6
10-.6
11-2.3
12-2.3
13-2.3
14-2.3
15-2.3
16-2.3
Anything seem amiss?
Could it possibly be a bad board at this point? What else could I do / check?
The IC voltages should be the same as a Sea Urchin build
On the sea urchin, pin 4 is 0 and 9 and 10 are 2.4
I got 2 on pin 4 and 4.6 on pin 9 and .6 on pin 10.
An audio probe shows I have audio out on 15, but no audio in on 16?
What did I do wrong?
If you have voltage on pin 4 and pin 9, maybe you have something shorting to ground somewhere?
Quote from: lincolnic on September 04, 2014, 10:27:07 PM
I'll agree with you there, but I don't see a single solder bridge anywhere and it's making me nuts.
I hear you, it's frustrating. Maybe put on a good record and break out the multimeter to see if anything has ground continuity that shouldn't have it.
Quote from: lincolnic on September 05, 2014, 04:46:40 AM
Great idea, that's next.
Silly thought, bad op amp?  I had some weird symptoms with some bad ones a while back.
Quote from: wgc on September 05, 2014, 12:28:43 PM
Nope grabbed a known working pt3399 but not the tl072
copachino
Quote from: jimilee on September 05, 2014, 12:51:25 PM
did you mada it work¡???
Quote from: copachino on September 16, 2014, 03:25:38 PM
Nope, never did. I ordered some boards, gonna try a second one.
