Boneyard Issues--Resolved!
Started by Myramyd, April 28, 2011, 07:07:52 PM
Oooh...
If your battery is draining fast, that might mean you power is leaking to ground. Does that battery get hot while that's happening?
Myramyd
Doesn't seem to be getting hot yet. But, it went from 9.33 to 8.09 pretty quick.
I can't see anything off hand where the power lines are going to ground.
But, that would make sense. It does sound a little like when a fuzz gets low voltage fed to it.
J
If your battery died that quickly, I'd be using my DMM to do a continuity check between ground and power. You DEFINITELY have an issue with your power, and you need to sort that out.
jacob
Myramyd
Okay,
My current DMM doesn't have a continuity check on it (stupid Rat Shack!). So I'm going to get a new one and trace the power & grounds with that. I will report back after that happens. Hopefully tomorrow.
J
I'll put some detailed thoughts in ASAP, but one thing: DC on pins 1-2 and 5-7 should be 0v as you've shown. The power supply is bi-polar, and the reference voltages sits exactly in the middle, which is 0v. It's the same with the Plexitone, except in that case it's +-12v instead of 9v.
I'll try and read over everything else tonight and post more.
Myramyd
Thanks so much Brian, I really appreciate it!
J
Correction, I forgot that the order of the op-amps in the PCB design is different. Here are the approximate voltages you should be reading:
This is off an 8.89v supply using a TC1044SCPA charge pump and LM347n
1-> -2v
2-> 0
3-> 0
4-> 8.86v
5-> 0
6-> 0
7-> 0
8-> 0
9-> 0
10-> 0
11-> -8.39v
12-> 0
13-> 0
14-> 0
Interestingly, pin8 sometimes seems to read differently on mine. At first I used an auto-sensing DMM to do the voltages and it did not seem to work well. On my old cheapie I got more reliable results. The output should be 0v, and that's why a de-coupling cap was not used in the original design, I'm guessing.
More later.
Myramyd
So, I'm back to looking at this again...
I can't find any new issues. I can say that there is no voltage reading at any of the grounds.
I'm about to just order a second board and start over with all new parts. I have a feeling there is a bad part or two somewhere but I don't know how to figure out which ones. I suppose I could just try a new LM347N first.
Any other ideas I can try?
J
Myramyd
#23
Here's an update...
I got a new LM347N and replaced the MAXX1044 with a TC1044 for good measure.
The voltages now match Madbeans and it overall has a decent tone but there are still two issues.
1- Not enough gain: The "high-gain" setting sounds about like what I think the low-gain should sound like. The low gain is about like a TS on half gain. This is with both gain knobs on max.
2- Tone knob: doesn't really function. It's more like a high cut. In the demos I've seen people have it about half way and it's pretty trebly. With mine, all the way up still sounds a little dull.
Any thoughts or should I buy a new board and start over? This thing has taken the damn life out of me!
J
