MXR Blue Box mod?
Started by J. Ignacio, August 20, 2014, 01:37:49 AM
J. Ignacio
 Hi guys, this time i come with another question. I have a MXR Blue Box and i want, if it's possible, add a toggle spst to cut the octave and use only fuzz. Yes, you will tell why you have a octave-fuzz pedal if you don't want octave. Well, i don't know, it's funny
Can you help me?I think if cut a pin of CD4013 the octave will dissapear
Thanks
ggarms
I was going to do this for a friend before he decided against it. From what I found on the interwebz, removing c11 does the trick. You could make it switchable if you wanted. Mind you, this was found in a google search, so as always, proceed with caution.
J. Ignacio
#2
Quote from: ggarms on August 20, 2014, 02:31:59 AM
Thanks for answer. Yes, i saw this mod in web but i think that this mod is to increase "bass" on pedal but not to cut the octave or i understand very bad  :-[
Edit: i ask permition to post this link. Here is the mod. This guy change the value cap to 0,0022uf instead 0,01uf original value
Betty Wont
I thought turning the blend knob took out the octave. It blends between pure fuzz on one end to pure octave on the other.
Quote from: Torgoslayer on August 20, 2014, 01:39:53 PM
That's exactly how it works. If you don't want the octave, just leave the blend knob all the way on the fuzz side. No need to mod anything.
