ROTOR - Auto-panner/Leslie esque simulator [audio demo]
Started by Cloverleaf, August 19, 2014, 04:27:55 PM
Cloverleaf
Hey folks!
Here's a seperate topic about the Auto-panner I posted about earlier in my introduction thread. I recall that jimilee asked for an audio demo so I did a quick little recording using two amplifiers in a stereo setup. In the audio demo I'm using an expression pedal to modify the panning speed of the effect (this is also switchable).
On the left I'm using some sort of Marshall clone from the 80's (it was given to me by an old friend a couple of years back, runs on three AX7's and two EL34's with a Baxandall tonestack... or at least I think so :o ) and on the right sits a 60w Fender Deville.
I'm also using a MiM Fender Strat with DiMarzio hotrails in the neck and DiMarzio 'buckers in the bridge. The bridge 'buckers are coil-tappable.
Other effects I used were a GrindCustomsFX Tenebrion reverb on the Marshall clone, a touch of spring reverb on the DeVille and later on an MXR Phase-100 clone and a DOD FX65 chorus.
Most of the 'modulation' came from the Auto-panner though. Guess it 'sounds' like modulation due to the ears being tricked there's a phase shift of some sorts going on, yet all that happens is the fluctuation of volume from left to right. I don't know a whole lot about this subject, so please forgive me if I'm wrong (I'd love to learn what causes this funny effect though!).
Oh, also, I could finetune the effect to be completely off/on on the respective left/right channels, but I figured this sounded best. Sounds a little like some sort of Leslie, I really dig it ;D
Enough text, on the audio demo! I recommend listening to it with some good headphones to emphasize the panning effect.
[soundcloud]http://soundcloud.com/kvdmeulen90/auto-panner-lesie-sim-demo[/soundcloud]
And some photos:
EDIT:
Here's a photo of the Strat I mentioned:
micromegas
Software Developer @ bela.io
Man, there is really nothing I don't like about this pedal. Thanks for sharing the clip. I love the way it sounds with the phaser going. I kind of want to build one now. You're not helping me avoid branching into analog synth stuff. I've drooled over at MFOS a lot. Just curious, what's going on with the unpopulated sections of the board?
Cloverleaf
Thanks everybody! Glad ya'll like the effect :)
Quote from: Leevibe on August 21, 2014, 03:28:33 PM
Thanks for the compliment! Haha, I know the problem; when I first heard a sample of this effect on MFOS I just HAD to have it... immediately ordered the PCB while I still had some unpayed bills due... hehe.
Anyway, the unpopulated section of the circuit is actually a ramp up/ramp down control for the speed, much like the original Leslie speakers had two speed settings. I figured since I was going to use an expression pedal to fluctuate the speed while playing I didn't need it, as I can gradually increase/decrease the speed myself (or less gradually for more extreme effects).
Your demo is really great, now I want one.   ;D     I do have a couple of questions.
I know this pedal runs on +/- 12v.  In your previous post I think you said that you were powering it with a 9v adapter.  I assume that's what you're doing on vero.  How do you accomplish that?
How effective is the ramp up / down feature?  Is it at all like a Leslie?
Quote from: bcalla on August 22, 2014, 06:37:48 PM
Yeah, I'm curious about that too. I would love that feature I think.
Damn, thats a sound I've been looking to get for a very long time.  Don't know how I'd work stereo into my live rig but that sounds just crazy good.  Nice and subtle but however the pseudo doppler effect is done (either real or imagined) is too cool.
Cloverleaf
#9
Thank you very much!
I have no idea how effective the ramp up/down feature is, I didn't populate that part of the board so I can't try it out unfortunately. I decided that due to my plans to use an expression pedal to manipulate the speed, I wouldn't need it as I could just gradually increase/decrease the speed myself.
Indeed, I am using a regular 9v adapter. I just take +9v from the 2.1mm adapter jack and use a voltage inverting circuit on vero to get -9v. I did alter some resistor values (on the main PCB - required for proper operation I guess) though, can't recall exactly which values but if you check out the project page on MFOS it'll tell you which resistors to alter for +15/-15v operation. I believe I decreased the values and even used trimmers in some spots. Fiddled around with 'em for a while 'till I was satisfied :)
Quote from: gordo on August 23, 2014, 03:56:23 AM
Likewise! I simply use two amps set-up facing eachother at home. If I'd do it live I'd probably set the two amps as far apart from each other as possible, to achieve maximum effect.
EDIT:
I'm sorry for the slow reply guys, had quite a busy weekend.
slimtriggers
This gives a nice solid +/-12v if you want to go this way (they do a 15v brick also).
Cloverleaf
Thanks for that juan, that'll definitely come in handy!
