Boneyard Problem - no sound (voltages inside)
Started by memor82, August 17, 2014, 04:19:33 PM
memor82
Quote from: jimilee on August 19, 2014, 01:48:28 PM
Quote from: memor82 on August 19, 2014, 01:28:19 PM
Quote from: Haberdasher on August 18, 2014, 08:26:16 PM
hopefully the noise will clean up some once it's boxed.
if they are diffused yellow & green, those things are often very dim.  the only thing you can do is maybe try a lower value on their resistors like 2k2.  it might take some experimentation.
Thanks Haber ;)
I'll buy some yellow BRIGHT and green BRIGHT led with the same 4,7k resistors :D
Just a doubt.
The ground wire from input sleeve-> output sleeve.
Can I'll remove it when I'll box the pedal?
Thanks!
Yep, it will get continuity through your enclosure.
Perfect, Thanks!
Very kind of you!
best regards, Andrea
