Boneyard IC ICL7660S and power suply
Started by memor82, August 13, 2014, 02:46:29 PM
memor82
Hi everybody!
I just made an order of material for my Boneyard.
I've ordered this ICL7660S:
http://www.musikding.de/ICL7660S_1
They say that it is compatible with "Max1044".
So the question is..
With this ICL7660S I've to use a normal 9V external power suply or a 12V?
And musikding says " Can multiply your voltage to make 18V out of a 9V battery ".
Why 18V?
"MAX1044" must converts 9v to 12v
So with MAX1044 or TC1044SCPA  the internal volts must to be 12v?
or..am I wrong?
Thanks for your patience
and sorry for my english
Andrea
GrindCustoms
The Boneyard use an internal charge pump like the MAX1044/TC7660S/ICL7660S.
What the charge pump does is convert your 9V DC input into 18V for greater headroom and dynamic in some circuit.
Simply use your standard 9V supply for that circuit and everything will be fine.
Rej
memor82
Quote from: GrindCustoms on August 13, 2014, 03:38:49 PM
Rej
Thank you!clear..
So the real plexitone has 18v internally?
memor82
Rej
Thank you!clear..
GrindCustoms
I don't know if it has one in the stock pedal. If Madbean put one in there it's because it was meant to be.
Just to add to the conversation....
NO charge pump is going to provide 18V from a 9V source if used properly. You WILL lose some power due to diode drops, leakage, etc. You can expect to see more like 17V on the output.
memor82
Ok understood.
So I'll use the LF347 and the ICL7660S with 9v external supply and everything will be fine
and with an internal voltage about 17v :-)
thanks to all  ;)
GrindCustoms
Quote from: memor82 on August 13, 2014, 05:39:36 PM
Ok understood.
thanks to all  ;)
All of the Yes! :D
