Solder mask paint?
Started by ggarms, August 10, 2014, 04:05:30 AM
Gledison
Hi. I have only experience with this one:
It works very well!
copachino
Quote from: Gledison on August 11, 2014, 10:30:06 AM
It works very well!
i still have 3 of this over my box, and they are really a pain in the ass, they dont say it but you need to let the ink dry before you use the mask, you need to apply it really careful to get the right amount, i damaged many boards with that, but if you are using some silk screen to apply it this its perfect, for hand apply its really hard to get good results, im giving some of my solder mask on the PIF section but no-one seems to care, if you want some please tell me.
Gledison
Quote from: copachino on August 11, 2014, 02:03:03 PM
It works very well!
Hey, I've got a lot as well, thanks.
I think it depends for what you need. If you want for profi use than might be a pain in the butt indeed. I'm using for my pedals and only to protect the board against corrosion and to easier the soldering. One thing u could do is to brush it over the board and cover it with a polyethylene foil, than apply the pads mask on the top of it. If u do it carefully, removing the little air bubbles, might get perfect. If u leave it to dry overnight or for a 30 min in a toaster oven, u can have better results. Always by adding the film on the top, PE does not adhere to the epoxi.
I hope u get the results you want and please let me know how is it going with the new one u are using!
Cheers
copachino
Quote from: Gledison on August 12, 2014, 06:37:50 PM
It works very well!
Cheers
dry film its the best, i have those chinise soldermask on the box, i will neve use it, i can give you some of the dry film if you want to try i have a hugh roll of 200 feet long per 24" width and i wont use all of it never jajaj
Gledison
Quote from: copachino on August 12, 2014, 08:38:17 PM
It works very well!
Cheers
Thanks mate but I don't have a laminator and I dont have much space to get diff devices! :(
I agree that the dry is the best but u also need the reactive solutions and a. Nice UV lamp. Maybe one day...
copachino
Quote from: Gledison on August 12, 2014, 09:10:47 PM
It works very well!
Cheers
in fact no, you cant use sunlight(i do) its better than my UV lamp, reactive solution its soda ash(you can get it at pool supplies really cheap) and laminator man, this things are for pro use, but with an airon just like you do toner transfer its more than enough, im telling you cos i do it that way
Gledison
Quote from: copachino on August 12, 2014, 09:29:34 PM
It works very well!
Cheers
Hmmmm! Hey bro, what about a vĂ­deo or pic short tutorial? Im pretty sure lots of guys here would love it!!
And yeah, i would live a bit of the dry film to try :)! Cheers mate
copachino
i will try to make one soon, probably on a lavache one, also using a dry film photoresist to etch the board
