Pitch Pirate mask
Started by ggarms, August 05, 2014, 10:57:39 PM
ggarms
So I found the match to etch the pitch pirate on fsb, but I can't get the sizing right to print it. Does anyone have a pdf? Bean spoils us :)
Soup39
#1
Hit up Cody - self destroyer. On his site they remained silent he showed one that he etched, he might be able to provide dimensions.
Or haber who has etched some as well.
Quote from: ggarms on August 05, 2014, 10:57:39 PM
Was it this layout? http://music.codydeschenes.com/wp-content/uploads/2014/08/Midfi-Pitch-Pirate.pdf
Just print it 100% with no scaling.
copachino
Quote from: selfdestroyer on August 06, 2014, 06:30:30 AM
Schematics or parts numbers???, i want it jejeje, sorry to mix post but anybody has the size of the little angel??, i want to build it but with no luck about the size
ggarms
Cody, that's exactly what I was looking for. Keefe hooked it up as well. Thanks guys :)
Sizing "should be" relatively easy if it has an op amp or other IC in the circuit.
1) Make the layout available in MS Paint
2) Set the print scale to 50% and print.
3) Use an IC socket to see if the IC pads line up with the IC socket.
4) Adjust print size in small increments (~5%) until the IC socket pins line up with the transfer pads.
DONE!  8)
