size on 1590A
Started by copachino, July 19, 2014, 04:26:59 PM
copachino
im under a englishman on a 1590A enclosure but im not so sure how many space i have on a 1590A enclosure, my pcb its 1.30x1.09 inches, but since i dopnt have a 1590A enclosure im not so sure about the size,  what are the space on the 9mm alpha  pots?? i have 0.15 inch spacement, and 0.1 for the spdt switch
To check sizes there's a proper sized template you can print out at the end of this document.
http://www.madbeanpedals.com/downloads/BabyBoardGuide.pdf
copachino
Quote from: davent on July 19, 2014, 05:02:13 PM
i know the outside measuraments, but i was hoping to get the inside, i have seen beans baby boards to have also 1.30 inches but im not sure if they fit on every 1590A on the internet, there are many enclosures called like that
Page 17 of the document, you'll have to measure a printout... or Hammonds datasheet, if you're using a Hammond.
http://www.hammondmfg.com/pdf/1590A.pdf
