Picture Showcase - post your best pedal work
Started by madbean, June 28, 2014, 10:13:41 PM
Double take
Phase monster 45->90
Purpleplexi
Tenebrion
Sharkfin
Zpsdx
Cortexturizer
Here's a couple of mine that I am really happy with aesthetically:
Loving all of your work gents, I remember some from earlier some I've seen for the first time, all golden.
muddyfox
I remember most of yours, Marko. I don't think I've seen the one with the lcd before, though? What's that one?
And how did you drill the square hole for it?
And a tip of the hat for your usual window frame backdrop, I love that one.
Cortexturizer
Hey nice to know some of these have been remembered.  The led display one is my Miles Ahead fuzz face platform, with the added voltmeter (the display obviously measures the collector voltage of Q2) but there's all of the mods in there, or space left for em so it's easy to experiment, polarity switch, everything socketed basically, and there's a probe as well so that you don't need a multimeter, you can use the pedal's own voltmeter to bias everything. And so on...
The hole drilling was hard as hell, I drilled consecutive round holes and then sanded em so they merged together and after a while, I ended up with a square hole. It was hard.
Tremster
#20
muddyfox
Quote from: Cortexturizer on August 28, 2014, 09:15:13 AM
I tried this once and failed miserably. Aluminum is supposed to be a soft metal, nothing soft about the one I tried to drill for a square hole!
So I completely ditched the idea until I get a scrollsaw or something of the sort so that a machine can do the hard work.  ;D
micromegas
You forgot the Sharkfin build, Marko, that one sounded/looked amazing.
Software Developer @ bela.io
muddyfox
He prolly sold it for it's weight in gold...
Kyurie
Hi! The "Tarantula!" mixer for my client-bassist is finished. The specification and design proposed by him.
The input signal is divided into three signals, two of them go to send/return sections. Any pedals can be plugged into the send/return sections and finally "dirty" signal is blended with the clean signal. So it has solved the problem of cutting the low specter of the bass signal when it goes through guitar pedals. And optionally three guitars can be plugged into the input and returns of this box and it becomes the floor mixer  ;D
The preamps are + 6Db
The front panel was engraved and painted.
The PCB is laser engraved, chemically treated and soldered classically :)
Cheers from Belarus!
Tremster
All of Kyurie's builds on diysb are very, very impressive, as is this one :D
Kyurie
#28
Quote from: lincolnic on September 01, 2014, 04:13:34 AM
That's one hell of a first post.
QuoteIt so is. Welcome!
Quote from: alanp on September 01, 2014, 05:27:14 AM
Thank you so much! My favorite business and Your warm reviews make me happy! :)
Guybrush
#29
My proudest moments.
The guts are all shocking though so those photos don't belong here.
Edit: Wrong photo.
