Aquaboy Deluxe w/Road Rage in a 1590BB?
Started by peAk, June 24, 2014, 04:40:38 PM
Trying to decide what enclosure I want to use for this AB Deluxe w/Road Rage.
Is it possible to fit it all into a 1590BB? If it's a lot of trouble, I may just go with one of these bigger slanted enclosures I have.
I looked through the build reports but didn't see any.
GrindCustoms
You should be able to fit the roadrage under the ABDX pcb without any issue, if you don't have short electros just lay them on their side.
I have'nt use a RoadRage in mine, but i built 15Vreg/Filtering setup that is hidden under the board so i can use the available 18V outlets on my PSUs.
If you need some small ele caps I might have a couple. If not Paul (chromsphere) has a bunch in his web store. you should be fine though. There should be enough room in the BB for the RR and the ABDX. I believe MB has a RR3PDT switch board now. That might save you a headache or two.
Stomptown
I would also get some double sided foam tape so you can secure the road rage in place and keep the bottom side from shorting out on the enclosure. There may be better ways I don't know about but this seems to work fine...
GrindCustoms
Quote from: Stomptown on June 24, 2014, 08:49:45 PM
+1
It's all i use and with time it just get stiffer fixed inside, reliable solution.
Stomptown
Another option might me the 3PRR (madbeans new 3pdt mounted road rage). It looks like you could fit it in there!
Guys, thanks for the info.
I still may go with a slightly larger enclosure just to have a little extra space to work with.
Quote from: peAk on June 25, 2014, 01:21:40 PM
Everything is bigger in Texas! hahaha sorry I had to  ;)
Quote from: flanagan0718 on June 25, 2014, 01:47:02 PM
ahaha...funny that you mentioned that because I just finished a Wolfshirt and it's in one of those huge octagon Hammond enclosures  :o
Stomptown
That will just give you more room for creativity and artwork! I used to be into squeezing projects into the smallest possible enclosure but I finally realized that it's not necessary. I only use 6-8 effects on my board so why worry about it....
Check out this enclusure; it would be a nice alternative with some extra room:
http://www.hammondmfg.com/pdf/1590Q.pdf
Quote from: Stomptown on June 26, 2014, 04:50:51 AM
that's nice size Jon, will have to check into that.
1790's are also nice for a little more room.
