Kinglayer volume in effect when effect is off
Started by AntKnee, June 19, 2014, 09:22:47 PM
AntKnee
When I have the pedal off, the volume knob still affects the signal. I wired it for buffered bypass and used a 2pdt. Maybe I didn't translate something correctly to this switch?
AntKnee
I may have overheated the #4 lug on my dpdt. I'm switching them out to see if it fixes it.
AntKnee
I am pretty sure it was an overheated switch. I do that sometimes with the dpdt switches. I swapped in a 3pdt and it works properly.
oldhousescott
Glad you were able to get it sorted. I had a similar issue with a DPDT in a klone, but in my case I neglected to solder one of the lugs. Your solder joints all looked fine though.
