Pork Barrel - Direct and Wet signal levels
Started by harpplayer, June 18, 2014, 11:11:00 AM
harpplayer
Hello!
I finished building my pork barrel and the layout really helps when compared to my old ce-2 clone.
I want to try something new with this one and be able to ajust the levels both for the wet and direct signals. Tonepad suggests a 250kc pot in series with the 47k resistor (R27 on the pork barrel), so I think that having the same approach with R9 would do the trick for the direct signal.
Would it be ok to set the potentiometers as voltage dividers? I ask that because I don´t have C log potentiometers, and they are really important for that mod (meant to be a variable resistor). Setting the potentiometers as voltage dividers gives me a more even response with a regular log pot, but I am worried about impedance issues.
Tks!
André
